Fecha actual 17 Ene 2019, 18:58
Nuevo tema Responder al tema  [ 59 mensajes ]  Ir a página 1, 2, 3, 4, 5, 6  Siguiente
**Manual para Flysky GT3B/GT3C firmware 0.6.x** (Videos)
Nota **Manual para Flysky GT3B/GT3C firmware 0.6.x** (Videos)
Pues nada, unos nuevos Videotutoriales para las Flysky reprogramadas.
En esta ocasion para Firmware 0.6.x.
Como Asignar numero de canales a cada memoria:
Como Activar la funcion de Doble Direccion(4WS) y hacerla funcionar:
Como Activar y configurar el DIG:
Como asignar y configurar los canales para uso en 3 posiciones:
Como simular una caja de cambios de varias velocidades:
Como activar la Alarma de Inactividad: (para que no te la olvides encendida)
Como activar la funcion de Full Brake (con boton):
Saludos, Carlos.
Última edición por meao el 10 Oct 2012, 20:53, editado 4 veces en total
04 Sep 2012, 22:34
Nota Re: **Manual para Flysky GT3B/GT3C firmware 0.6.x** (Videos)
Fotos referecia para identificar los botones:
Global characteristics:
- 63 model memories, first 8 in EEPROM, rest in FLASH
> numbers 10-19 will show with Right-Arrow
> numbers 20-29 will show with Left-Arrow
> numbers 30-39 will show with Left+Right-Arrows
> numbers 40-79 will show like 0-39 with additional Percent symbol
- added Subtrims
- added SaveAs to save model config to another memory location
- added Global Setup menu to change function features, including backlight time,
battery low voltage, etc.
- dead zone for steering and throttle
- added key mapping specific for each model memory
- calibrate menu will be automatically invoked after first power-on with
this firmware, so 6 menu items will start to blink
- when radio is powered on with steering/throttle not in dead center,
it beeps 3 times if poweron not-centered warning is allowed
- added inactivity alarm
- added settable servo speed
- added 4WS, DIG, MultiPosition functions
- added timers (up, down, lap, lap count)
Buttons:
- it is now possible to differentiate between long press (>1 second) to
normal button press (short) and it will be recognized like "ENTER-long"
- Trims, DualRate and other popup informations
> now shows changed value only temporaly (5 seconds or till another
key press), values are saved to EEPROm automatically when it disappears
> when autorepeat disabled on trims (default), reset trim to 0
by pressing both trim keys together for long
(eg. TRIM_LEFT-long + TRIM_RIGHT-long and similar for channel 2 trim)
> while value is showed, it is possible to change it with rotate
encoder also
> when value set to reset_value (usualy 0), longer beep sounds to
attention to it and short pause is intruduced to ignore keys
Main screens:
- changeable by rotate encoder:
model name
battery voltage
timer1 - ENTER and ENTER-long operates this timer, not standard menu
timer2 - ENTER and ENTER-long operates this timer, not standard menu
Standard menu:
- swapped behaviour of ENTER and END when editing items, ENTER now select
next value and END (+ ENTER-long) will end editing items
- ENTER-long on ABS will leave menu also (as BACK)
- Trims are now only for steering and throttle
> trim move center position without moving endpoint positions
- Expo
> value for channel 2 is splitted to forward and back and is indicated
by arrows
> positive values are those You want to use like at Spektrum radios
- DualRate
by arrows
- SaveAs
> choose menu MODEL and press ENTER-long
> menu MODEL will blink
> choose memory position where to save model config
> press ENTER/BACK to save it
- Model number of channels and Model reset
> choose menu NAME and press ENTER-long
> menu NAME will blink
> choose "C" for number of model channels or "r" for model reset
- reset will show NO/YES
- Subtrims
> subtrim moves center position together with endpoint positions
> choose menu TRIM and press ENTER-long
> menu TRIM will blink
> set subtrims for each channel
- channel speed
> choose menu D/R and press ENTER-long
> menu D/R will blink
> select channel
> for channels 1 and 2 (steering and throttle)
- turn wheel left to show left arrow
- this represents Turn speed or throttle speed
- turn wheel right to show right arrow
- this represents Return speed or
"throttle speed only for forward" (OFF/ON)
> select required speed 1...100%
- 100% means no delay
- 1% means above 4s delay end to end
- directly setting channel value of channels 3..8
> values for 4WS and DIG channels cannot be changed
> this can be used instead of mapping some key to appropriate function
> choose menu EXPO and press ENTER-long
> menu EXPO will blink
> select channel and press ENTER
> select value in range -100..100 and press enter
- mixes 4WS, DIG, throttle brake cut-off (for boats with forward-only
throttle), Multi-Position (to set arbitrary up to 8 positions),
brake channel (to send brake side of throttle to extra channel)
> choose menu EPOINT and press ENTER-long
> menu EPOINT will blink
> select one of mixes 4WS (4), DIG (d), brake cut-off (b),
multi-position (P), brake channel (8)
for mixes 4WS, DIG:
> press ENTER and choose channel for this mix or OFF
- for dual-ESC steering (boat, tank, ...) select DIG channel 1 and
with steering D/R reduce required ESC travel (at 100% it will go to
contra to allow steering at place)
> press ENTER and set mix in range -100...0...100 %
0% is default and means both channels have same max steering/throttle
100% means 100% reduce on rear steering/throttle (eg. no steering)
-100% means 100% reduce on front steering/throttle (eg. no steering)
> for 4WS press ENTER and select crab (CR1) or no-crab (CR0)
for Multi-Position:
> there are 4 Multi-Positions identified by numbers 1..4, they have
8/6/4/4 positions
> press ENTER and choose channel for this function or OFF
- channel can be "D" also, which means map to DIG function
> press ENTER and set channel value for first position
> press ENTER and set channel value for second position or END
> ... up to eight position
for brake cut-off:
> press ENTER and choose OFF or CUT
for brake channel:
> press ENTER and choose channel fro brake or OFF
- Key mapping specific for each model:
> choose menu REV and press ENTER-long
> menu REV will blink
> choose trims (id: 1 2 3 d) or other keys (CH3: C, Back: b, End: E) or
if trim is OFF, then also trim keys (id 1 2 3 d with left/right arrow)
> press ENTER and modify first setting
> press ENTER and modify next setting
steps of settings of trims (1 2 3 and D/R):
- sequence:
function -> buttons -> step -> reverse -> opposite_reset -> previous_val -> rotate
- function: selected function listed at the end of manual
- B buttons:
MO - momentary, hold left/right trim key to get end values,
when nothing pressed, servo is at center
NL - no long keys, long press is the same as short press
AR - autorepeat is on
RS - long press of one of trim keys will reset to
centre/reset value
EN - long press of trim key will set to coresponding end value
- step: select trim step for one trim key press (1, 2, ... 100, 200),
not available when buttons MO or fuction is list of items (multi-position)
is identified by symbol "V"
- RE reverse:
0 - no change
1 - swap left/right trim keys
- OR opposite_reset: not available when buttons MO
0 - no change
1 - when trim key is pressed and value is at opposite
side of center/reset, set value to centre/reset,
- PV previous_val: available only when buttons MO or fuction is list of
0 - no change
1 - instead of setting value to centre/reset when key is released,
it is set to previous value, which was active before key press
- RO rotate: available only if fuction is list of items (multi-position)
0 - no rotate
1 - rotate from max item to first item and back
steps of setting of keys (C b E 1< 1> 2< 2> 3< 3> d< d>):
- sequence:
function -> momentary -> reverse -> prev_val -> function_long -> reverse_long -> prev_val_long
- MO momentary: only available for 2-state functions (channel, ...)
0 - switch, key press will switch something (channel value, ...)
1 - momentary, value change will be active only while key is pressed
- RE reverse: only available for 2-state functions
0 - normal, no-press or default value is left endpoint
1 - reverse, no-press or default value is right endpoint
- PV prev_val: only available for 2-state functions
0 - key release or OFF state sets value to left endpoint (noREV)
1 - key release or OFF state sets value to value active before
key press or ON state
- function_long: function applied when long press of key happens,
choose from the same list as function,
identified by "V" symbol
- reverse_long: same as "reverse" + "V" symbol
- prev_val_long: same as "prev_val" + "V" symbol
steps of settings of ch3 potentiometer (if enabled at global config):
- sequence:
function -> reverse
- RE reverse:
0 - no change
1 - swap left/right sides
Operating timers:
- select timer1 or timer2 main screen with rotate encoder
- timer1 is identified by left arrow, timer2 by right arrow
- lap count is written to 3char LCD place
- timer value is writen to 7seg + 3char LCD place in format:
0000 - MMSS minutes, seconds
0000 % - SSHH seconds, hundredths (0.01 seconds)
- press ENTER to set timer params, use it as usual menu:
H set throttle trigger start OFF/ON
timer will start after
throttle forward applied
A set alarm 0..255
in laps for lap counter
in minutes for others
P set timer type:
OFF timer is off
UP up timer
TxS start/pause timer
TxR stop + reset timer
DWN down timer
TxR stop + reset timer and save rest time
to lap times
when alarmed at time 0, starts counting
up with "V" symbol blinking
LAP lap timer - 100 lap times are saved
TxS record lap time, show it for 3s blinking
and during this time presses are ignored
to eliminate double click
when timer not running, start timer
when timer alarmed, stop timer and save
lap time
TxR stop timer
LPC lap counter - till 255 laps
TxS increment lap counter, minimum 3 seconds
between presses are required to eliminate
double click
TxR zero lap counter
- pres ENTER-long to show saved lap times (only for LAP and DWN timers):
> It is possible to see lap number (indicated by 'L' at 7seg number)
or time showed as other timer values. Press ENTER to switch between
lap number and time value
> use rotate encoder to switch between lap numbers or lap times
> there are special lap number identificators also at 3char display:
- Txx - total time, 'xx' is number of laps
- Axx - average time, 'xx' is number of laps
- RES - pres ENTER and lap times will be erased, it is also
displayed when showing lap time
Calibrate menu:
- enter it by wheel right-turn and ENTER-long
- 6 menu items starts to blink (+ 2 arrows if CH3 is potentiometer)
- use END or ROTATE to change channels
- there is also channel 3 representing CH3 button (for those who will do
some 3-position switch/potentiometer modification)
> There is 1K resistor connected between CH3 button and +5V, so
simply connecting linear potentiometer instead of CH3 button
will not work. Usefull results can be done with logarithmic
potentiometer 10K which has 1K at half of turn. Or eliminate
internal resistor to +5V, connect potentiometer between +5V
and GND and potentiometer output instead of CH3 button.
- there is also channal 4 representing battery voltage
- calibrate as usual (for channel 1/2 left+mid+right and ENTER)
> calibrated value will disappear from menu
> it is not needed to calibrate all values
- calibrate CH3 potentiometer (if selected at global config)
> only left + right positions
- calibrate battery (it will not be probably needed to use this)
> select channel 4
> press ENTER
> set your current battery voltage (measure it by voltmeter)
> press ENTER to save it or END to no-save
- press BACK-long or ENTER-long to end calibrate menu and save values
Key-test menu:
- enter it by wheel left-turn and ENTER-long
- if ENTER-long keep pressed, all segments on display will stay on till
ENTER is released
- now check keys by pressing them short or long
- if keys long pressed, an "L" symbol will appear left to displayed key symbols
- press BACK-long or ENTER-long to end key-test menu
Global setup menu:
- enter it by ENTER-long
- now menu items MODEL and NAME will start blinking
- select requested item by ROTATE and press ENTER
- use ROTATE to change value and press ENTER to end value changing
- press BACK or END or ENTER-long to end global setup menu,
values will be saved to EEPROM
- selected menu items are indicated by following symbols:
F firmware version (this of course cannot be changed :-)
L backlight time 5s,10s...10m...MAX
I inactivity alarm OFF,1m...10m
LOW POWER! battery low voltage 2.0...10.5V
C default number of channels 2..8
E maximum allowed endpoint value 100...150%
DANGER - values greater than 120% can damage
your servo or will not be possible
to transmit to receiver because of
2.4GHz HF module limitation
This danger zone will be indicated with a flashing
'%' symbol for values greater than 120%
A analog settings, dead zones, ADC samples used
steering dead zone S00..S50
throttle dead zone T00..T50
number of ADC values A_4/A_1
b beeps
key beep K_N/K_Y
value at center/reset beep V_N/V_Y
poweron beep P_N/P_Y
poweron not-centered warn C_N/C_Y
d long press key delay 100...1000 miliseconds
H setting of hardware features
reverse rotate encoder E_N/E_R (Normal/Reverse) - for GT3C
ch3 is potentiometer P3N/P3Y (No/Yes)
select ppm sync/frame PTS/PTF (constant SYNC/frame length)
select ppm length Lxx - 3-18ms for constant SYNC length
9-24ms for constant frame length
r global or all models reset
all configs (global+model) G_N/G_Y (No/Yes)
all models M_N/M_Y (No/Yes
o lock keys till ENTER-long No/Yes
Functions assignable to trims:
OFF - nothing, it is possible to assign each button individualy
as key
TR1, TR2 - trim of channel 1/2
DRS, DRF, DRB - dualrate of steering/forward/back
EXS, EXF, EXB - expo of steering/forward/back
CHn - change channel "n" value in range -100...100
STn - subtrim of channel "n"
SST - steering speed turn 1...100%
SSR - steering speed return 1...100%
CSn - channel speed for channel "n" 1...100%
4WS - 4 wheel steering mix -100...100%
DIG - DIG throttle mix -100...100%
MP1 - Multi-Position 1, switches position up/down
MP2 - Multi-Position 2, switches position up/down
MP3 - Multi-Position 3, switches position up/down
MP4 - Multi-Position 4, switches position up/down
Functions assignable to keys:
OFF - nothing
CHn - switch channel "n" value from one end value to opposite end
value. There is special handling for CH3 button. When using
3-position switch instead of CH3 button and momentary is
selected for this button, then centre 3-pos value will also
be detected and set to servo (use 1K resistor to GND to get
middle state)
CnR - reset value of channel "n" to centre
4WS - switch crab (CRB) no-crab (NOC) for 4 wheel steering
DIG - switch DIG mix between -100 and 100 (more useable when using
return to previous val key setting)
DGR - reset DIG mix to centre
MP1 - Multi-Position 1, switches position up (at END back to 1.)
MR1 - Multi-Position 1 Reset, switches position to first one
MP2 - Multi-Position 2, switches position up (at END back to 1.)
MR2 - Multi-Position 2 Reset, switches position to first one
MP3 - Multi-Position 3, switches position up (at END back to 1.)
MR3 - Multi-Position 3 Reset, switches position to first one
MP4 - Multi-Position 4, switches position up (at END back to 1.)
MR4 - Multi-Position 4 Reset, switches position to first one
T1S - start/pause timer1
T1R - stop + reset timer1
T2S - start/pause timer2
T2R - stop + reset timer2
BRK - switch on full brake, this overrides throttle position
BLS - battery low shutup, stop beeping, predefined to END-long
Última edición por meao el 17 Sep 2012, 20:01, editado 1 vez en total
04 Sep 2012, 22:34
Dos videos nuevos.
Saludos, Carlos.
07 Sep 2012, 22:02
Añadido manual escrito en Ingles.
Saludos, Carlos.
17 Sep 2012, 20:02
Kucho, añadido tutorial para la configuracion del simulador de cajas de cambios que me pediste por privado.
Saludos, Carlos.
02 Oct 2012, 00:23
Saludos, Carlos.
gracias Carlos, muy bien explicado ademas, todo un lujo tener este servicio tecnico !!
www.SDI4X4.com
02 Oct 2012, 07:58
Añadidos videotutoriales para activar la Alarma de inactividad(para que no os la olvideis encendida), y el Full Brake mediante boton.
Saludos, Carlos.
10 Oct 2012, 20:55
Carlos, como de costumbre he tocado lo que no debia :evil2: .
Los videos que colgaste para las 0.4.1** en cuanto a configuracion de NOVAK M2 y Direccion trasera, son validos para esta version 0.6.x**?
Edito. Veo que aunque en la pantalla aparece alguna letra diferente, hay correspondencia en las funciones..por ejemplo BNL es lo mismo que NOL (no long keys), BAR es la funcion RPT (repeat)
Aun asi, gracias por los nuevos videos.
18 Nov 2012, 19:45
Hay algun modo de poder ajustar el Trim al canal 4? para dejar centrada la dirección trasera del Super
Editado: Asigno al grupo 1 de botones la funcion STn. Al tener definidos en la emisora que voy a usar 4 canales me da la opción de escoger ST1, ST2, ST3 y ST4, correspondiendo cada una al trim de esos canales respectivamente.
19 Nov 2012, 00:22
Cuando estes en TRIM pulsa enter laargo y accedes al CH4, Suerte, saludos
WPL B14 C14 C14
1.0 U401 delrin dpBB2
1.9 SDIUnimog 406
1.9Mickey Thompson F150xL
1.9 TSL SSwampers scxJeep
1.9bajaclaws Mex d90 k44
1.9Tomahawks d110 pikcup
1.55 EcxL Temper30ºlink
1.9 xL EDGE 7link
2.2 HB Robers swx Mayhem2.0
2.2 RokLox BRUTUS
19 Nov 2012, 12:00
